Salta al contenuto principale
Rilasciata il 23 giugno 1996, modello NUS-001, la N64 è la prima console videogame a 64 bit di Nintendo e, fino al rilascio di Switch, l’unica (GameCube, Wii e Wii U potevano eseguire calcoli a virgola mobile a 64 bit, ma questa non è una vera architettura a 64 bit).
Incredibly dark image - help!
Hi,
Found my old N64 tucked away and trying to get it to work.
It’s on a SCART cable, and I get audio just fine, but the image in the screen is INCREDIBLY dark. Like not there at all. With brightness/contrast settings cranked on the TV you can just about make out the image.
I’ve re-seated and cleaned all cables and the expansion pack, and tried multiple games
Any ideas?
Thanks
Questa è una buona domanda?
Punteggio 0
5 Commenti
Hey there, are you trying to play your N64 on an HD TV or using a CRT TV?
da
HDTV.
Thanks
da
Have you tried using different games, and tried cleaning the N64 cartridge’s pins?
da
@spawn2048 how do you connect your N64 to your HDTV? Have you tried an older TV? what make and model is your TV?
da
@jmehnert yes, as stated in the original question…
da
Aggiungi un commento
1 Risposta
Risposta più utile
Hi!
I advise to clean the AV port first. If that didn’t worked, then replace the AV cable for a new one. If that didn’t worked, then try the console on a different TV to determine if there is something wrong with the console. If the image is like still super dark, then open up the console and clean it all (also the cartridge pins on the motherboard) and try again.
Could you also share some pictures regarding how the console is connected to your TV?
Please let us know how it goes!
Punteggio 2
2 Commenti:
Bit the bullet and bought a new cable. Now on AV rather than SCART and working fine. So either broken cable, or broken SCART port on TV
da
Hi!
Alright. Probably the cable (in most cases). You could try the SCART port with the new cable. Could be the SCART adapter as well. Good to hear that all is ok now :)!
da
Aggiungi la tua risposta
spawn2048 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 8
Ultimi 30 giorni: 38
Tutti i Tempi: 1,029
