Salta al contenuto principale
Una lavatrice a carica dall'alto di Fisher&Paykel.
Machine has error code 245?
Aquasmart washing machine is coming up with error code 245 ? Please explain this, thanks
Questa è una buona domanda?
Punteggio 0
1 Commento:
Hi @janet16013,
What is the model number of the washer?
Just verifying that the status light error code sequence on the washer is
1 1 1 1 0 1 0 1 as viewed from L→R . 1 = light on, 0 = light off?
da Condividi
Aggiungi un commento
1 Risposta
Have you removed the inner bowl and check under pump cover ,if so have youput the cover on around th correct way.Is the flapper inside housing of pump obstructed.
Punteggio 0
Aggiungi la tua risposta
Janet sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 36
Tutti i Tempi: 490
