Salta al contenuto principale
La TI-84 Plus CE è una calcolatrice grafica rilasciata nella primavera del 2015 da Texas Instruments. Include uno schermo a colori da 2,8 pollici, porta USB, app, memoria di archiviazione e una batteria da 1200 mAh.
Why is my calculator flashing validating OS
Why is my Calculator flashing validating OS
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Risposta più utile
It keeps turning itself off and back on? The easiest thing to try is holding the reset button on the back of the calculator for at least two seconds.
If that doesn't work then the battery is probably nearly dead. Leave it plugged in overnight and it should start working again.
Unfortunately newer TI-84 Plus CE calculators have trouble charging dead batteries so leaving it plugged in may not work. In this case you can try charging the battery in a friend's calculator, or buy a new battery. If the calculator is under a year old then you can contact TI Cares and they may send you a new battery for free.
Punteggio 3
Aggiungi la tua risposta
Dawn Chapman sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 8
Ultimi 7 giorni: 36
Ultimi 30 giorni: 356
Tutti i Tempi: 11,055
