How can I fix Furby's motion detector?
When you reset Furby he just goes into sleep mode and will not wake up until he is reset again.
Questa è una buona domanda?
Ottieni un rapido accesso alle guide, ai componenti e alle risposte per i tuoi dispositivi
not sure if you have a furby with a tongue but...according to the Furby hospital this procedure may work.
hold down tongue
turn furby upside down
shake furby a bit
turn right side up and release tongue.
You may have to hold tongue longer or try again. Just be gentle.
you factory reset my furby what the !&&* man
at least you fixed it
The only thing close to a motion detector circuit would be the Light sensor photocell in Furby's forehead. I would start on that one and see if it is still functioning. For way more info on the Furby, check this site. It has great information and plenty of autopsy pics. Attached is the diagram for the Furby's electronics. Hope this helps, good luck.
Thank you OT3, while I am not thrilled with the information you have provided, my sister will be.... She has asked for some help with hers'. Looks like I have another project.
Do you mean the tilt sensor? Like the one that picks up if they're swinging or like flying etc? (I have no idea how to find/fix them on eithet the old ones OR the newer ones, i'll keep a lookout for you though...)
Here's a guide that cleans/repairs the tilt sensor: https://furbytech.tumblr.com/post/167541...
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 11
Tutti i Tempi: 11,900
