The Disc could not be read.
Red Error Message: The Disc could not be read. Please read the Nintendo Gamecube instruction book for more information.
Questa è una buona domanda?
@johnllovesr try and see if it reads an audio disk as well as different game disk then the one you were trying. Sometimes a disk can cause this error.
It is possible that this is either a dirty laser or a failing laser. First try one of those commercially available CD cleaner kits. Run that a couple of times. If that does not work you could could try to increase the power to your laser. Follow this guide. Just be moderate, you do not want to burn it out. The other thing to try would be a recalibration of the lens. For that follow this guide. After that I'd suggest that you replace either the lens or the optical drive. Nintendo GameCube Optical Laser Lens Replacement Sostituzione gruppo lettore CD Nintendo GameCube
Guida
Difficoltà:
Moderato
30 - 45 minutes
Guida
Difficoltà:
Moderato
30 minutes
Guida
Difficoltà:
Moderato
30 minutes
Guida
Difficoltà:
Moderato
20 - 25 minutes
Ultime 24 Ore: 3
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 7
Tutti i Tempi: 24
