Salta al contenuto principale
Una Roku TV da 32" rilasciata da TCL nel 2018.
No image black screen
Questa è una buona domanda?
Punteggio 15
13 Commenti
da
@edwinlombeh have you tried the steps listed in the answer?
da
the television does not turn on, but the power on light
da
No display only stay on
led indicator
da
Tidak ada gambar pas pakai sate box
da
Mostra 8 altri commenti
Aggiungi un commento
3 Risposte
Risposta più utile
@cristinejo80172 you forgot to tell us if you have sound. Next turn your TV on Then use a flashlight and shine the beam at an angle against the screen. Do that in a darkened room. See if you can make out shadows or shapes. If you do, then it is your backlight that has failed.
If you do not see anything, unplug your set and remove the back cover. Then visually check the boards for any obviously damaged components. Check all the wiring and unplug the wires and plug them back in, make sure they are properly seated. Post some images of all of your boards with your question. Use this guide Aggiungere immagini ad una domanda for that so we can see what you see. It is possible that this is either a power board or a T-con board issue.
Punteggio 6
5 Commenti:
@oldturkey03 I have the same issue, and did the flashlight in a dark room.
Looks like a backlight issue. Any guides on how to replace it and what parts would be needed? Thank you!
da
yes me too can i get a guide on hoe to fix it
da
@rubimosqueda I bought new LED strips from Ebay.
And then followed these two guides from a youtuber.
https://www.youtube.com/watch?v=I32MBlbR...
https://www.youtube.com/watch?v=QdxSHeQF...
da
Full black image
da
@venu72785 what have you checked and what have you already tried?
da
No enciende, estaba funcionando y se apagó y no prendio
Punteggio 0
Black screen
Punteggio 0
Aggiungi la tua risposta
cristine joy catuboran sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 5
Ultimi 7 giorni: 26
Ultimi 30 giorni: 166
Tutti i Tempi: 5,346
