Salta al contenuto principale
Guide di riparazione e assistenza per chiavette USB, note anche come unità flash, pen drive o supporti di archiviazione USB.
USB Not detecting to pc
When I connect my USB flash drive to my PC, it doesn't show any data. "Please insert a disk into a USB drive (D:)" is the message that appears.
Questa è una buona domanda?
Punteggio 2
1 Commento:
Hi @rajeshgore43720,
Does the USB flash drive work OK when connected to other computers?
da
Aggiungi un commento
1 Risposta
I've had this before, when the USB was formatted as a Linux install. Most likely that the drive isn't formatted correctly. In Windows 10 File Explorer, you should be able to right click on the drive and format it to ExFAT for general file use (this will erase what is on it). This could also be happening due to damage to the drive. It would help to know what the drive was used for before this happened.
Punteggio 0
Aggiungi la tua risposta
Rajesh Goregaonkar sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 8
Ultimi 30 giorni: 17
Tutti i Tempi: 324
