Salta al contenuto principale
Il Samsung Powerbot R9250 è identificato dal numero di modello R9250. È stato rilasciato nel 2018.
Error code C03 shows up everytime
what should i do? The thing doesn't even follow any route anymore it just goes wherever it wants
Questa è una buona domanda?
Punteggio 0
1 Commento:
I've had this issue. To clarify the answer below, I seem to get items stuck behind the wheel/ square lug which attaches to the gearbox. The below youtube video shows taking it apart. You can also order a replacement wheel assembly as the motors do appear to start going out as well (and there isn't an easy way to get them).
https://www.youtube.com/watch?v=8jQlBv0e...
da
Aggiungi un commento
1 Risposta
The C03 error code on a Samsung POWERbot indicates that something is caught in the right driving wheel. You can clear the error by clearing the obstruction.
  1. Turn the power switch off that is located at the bottom before cleaning the robot.
  2. Use a blunt rod or tweezers to remove any foreign matter.
Punteggio 0
Aggiungi la tua risposta
Lee Guang sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 5
Ultimi 7 giorni: 17
Ultimi 30 giorni: 43
Tutti i Tempi: 1,163
