Salta al contenuto principale
Informazioni e guida di riparazione per il frigorifero Kenmore 596.7857*80*, un modello di frigorifero con congelatore inferiore senza funzione di erogazione del ghiaccio dallo sportello, dotato di sbrinamento automatico e interruttore per la resistenza anticondensa. Questa pagina contiene informazioni per i numeri di modello corrispondenti alla serie 596.7857*80*.
Not getting any ice
I have not been getting any ice, I have moved the shut off arm up and down a few times and waited 24 hours for it to make ice and have not gotten any ice. I don't know where the water filter is located so I haven't changed that. Any help you can give me is greatly appreciated. thank you
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Hi @edbakey
If there is no water/ice in the ice maker or if it is not working, first check if the freezer door switch is electrically OK and not that one set of contacts in the switch is corroded etc..
By design the ice maker does not function when the freezer door is open.
The freezer door switch is a changeover type switch which when the freezer door is opened, it releases to turn the freezer light on and the ice maker off and when the door is closed it re-operates to turn off the light and reconnect the power to the ice maker. It is the ice maker that turns the water inlet solenoid valve on and off as required.
Be safety aware if you decide to test if the switch is OK as there is 120V AC on the switch. It may be safer to disconnect the power to the refrigerator and use an Ohmmeter instead.
If the switch is faulty, search online for 12002646 to find suppliers that suit you best.
If the water inlet valve is faulty, search online for WP67003753 to find suppliers that suit you best.
Immagine Controls the flow of water into your refrigerator for ice-making and water dispensing functions.
Prodotto
Whirlpool SxS Refrigerator Water Inlet Valve - WP67003753
$73.99
Immagine Activates the interior refrigerator light when the door is opened.
Prodotto
Whirlpool Door Switch - W11396033
$27.99
Punteggio 0
Aggiungi la tua risposta
Ed Bakey sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 21
Tutti i Tempi: 261
