Salta al contenuto principale
Informazioni per la riparazione e lo smontaggio dello smartphone Android Samsung Galaxy Note20. Rilasciato ad agosto 2020.
How to fix Jamed volume button
How do I fix the jammed volume button on Galaxy note 20
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta più utile
Hi @katelyngolden
Here's a teardown video that shows how to open the phone to gain access to the Power button so that it can be checked or replaced if necessary.
The Power button removal procedure is explained between 6:25 and 6:35 minutes into the video.
If the Power button actuator is broken and needs to be replaced, search online for GH98-45544A (mystic black), GH98-45544B (mystic grey), GH98-45544C (mystic white), GH98-45544D (mystic bronze) or GH98-45544E (mystic green) depending on the colour of the phone, to find suppliers that suit you best.
Here's the ifixit Samsung Galaxy Note20 guide, that may also help.
Punteggio 1
If you're not ok with opening your phone.you can try using IPA/rubbing alcohol and use a Q-tip that soaked with IPA and try rubbing the button.thats what works for me.
Punteggio 0
Aggiungi la tua risposta
Katelyn Golden sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 5
Ultimi 30 giorni: 26
Tutti i Tempi: 316
