Salta al contenuto principale
Il Lenovo IdeaPad 110-15ISK è stato sviluppato da Lenovo negli Stati Uniti nel 2015. Il Lenovo IdeaPad 110-15ISK può essere identificato tramite il suo numero modello: 80UD.
Second Graphics card not detected
For me, The AMD Radeon card which comes as the second graphics card in this laptop, has completely disappeared in the system. Task manager, Device manager, or dxdiag do not recognize it, and amd driver installer doesn't detect it either, the copy of linux I also have installed on the system, doesn't recognize it either. I haven't opened it and would rather not. What do you think could be the problem?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi @amiratashi
Perhaps check in BIOS to see if there's an option to disable the AMD GPU.
If there's not, there's some reason why the GPU is not communicating with the I/O chipset on the motherboard so you will have to open it up and see if anything obvious is wrong. After that you may need the schematics to find out what's happened.
Here's the hardware maintenance manual that will help gain access to the motherboard
Punteggio 2
1 Commento:
Thank you for your anwser @jayeff
da
Aggiungi la tua risposta
Amir Atashi sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 14
Tutti i Tempi: 438
