Salta al contenuto principale
PC desktop all-in-one rilasciato da Microsoft nel novembre 2016. È dotato di un display touchscreen PixelSense da 28" con risoluzione 4,5K e processore Intel Core i5 o i7 Skylake di sesta generazione. Disponibile con 8 GB, 16 GB o 32 GB di RAM, 1 TB o 2 TB di archiviazione ibrida e GPU NVIDIA GeForce GTX 965M o GeForce GTX 980M.
Additional Detail on Connector Handling?
Immagine
Immagine
First, thanks for the website. Without this i would not have considered cracking open the old Studio. I've replaced both of the SSDs, and will also replace the fans, one of which was locking up, even after blowing 8 years of dust out of it.
I'm having a very hard time with the tiny little fan connectors. Don't want to rip the cables, even though I have new fans to put in.
How exactly does one release the connector? What does one press on, or push, or prod? I've got my trusty spludger here, but have tried pushing on the ends, the sides, and tried jiggling the connectors, but nothing seems to come out. I half-expected to press the "right thing", and hear a satisfying click -- nothing.
Also, the audio connector came out from the board instead of the inline connector, which I also couldn't figure out how to release.
Anyway, enough whining... I hope someone sees this and takes pity. Also, though I don't wish any ill will, I hope the answer helps someone else out.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Hello @ericleigh007! Let's get this little cable confusion under control!
It appears that the connector you have in the pictures (thank you so much for including those!) is a simple locking connection, meaning the only way to do it is to provide enough force for the clips (see picture) to release.
Immagine
This guide provides some very helpful tips on how to separate different types of connectors, including the one you are having trouble with; scroll down to step 10 for the connector you mentioned.
Good luck!
Punteggio 0
Aggiungi la tua risposta
Eric Snyder sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 24
Tutti i Tempi: 438
