Salta al contenuto principale
The second generation of the Recreational Active Vehicle with 4-Wheel Drive, commonly known as the RAV4.
How to fix my car's engine
The pipe transporting water on the turburator cracked hence water poured down while driving.The engine heated up smoke present until the car stopped and switched off.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Loss of coolant all the way to shutdown is not a good sign, there could be permanent damage and the engine could be beyond repair.
Check if the engine body or head is warped.
Punteggio 0
Preparati per le riparazioni future
Aggiungi la tua risposta
Brian Githinji sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 81
