Salta al contenuto principale
Modello A1311 / Metà 2010 / Processore Core i3 da 3,06 & 3,2 GHz o Core i5 da 3,6 GHz
Front Glass Screen Replacement
Hello, I am concerned about purchasing a third party screen.
Are the screens provided on iFixit Genuine Apple Screen Products?
I had a scenario where I replaced my iPhone screen at the mall and I instantly regretted it because my phone was running slow. Later, I found out that it was possible to add malware in those third party screens.
Can anyone shed some light on this?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
First off here’s the guide Installazione del display nell'iMac Intel EMC 2389 da 21,5" sadly iFixit doesn’t sell a replacement display for your system, likely do to the availability, typically iFixit sells used original Apple displays which have been fully tested.
The guide offers a link to a eBay seller of the display.
Punteggio 0
5 Commenti:
Thank you Dan for your quick response.
The iMac I have is iMac 21.5'' Mid 2010. I hope that is compatible with the screen, because I already purchased it! :(
da
I don't need the whole LCD screen replaced just the top glass part that is cracked.
da
@gracebear64403 - your question was a bit confusing as you vacillated between the cover glass and the display it’s self.
So the part in question is the cover glass iMac Intel 21.5" EMC 2389 Glass Panel unlike a iPhone display which is more than a cover glass it’s the. display and the cover glass here is just a custom cut sheet of glass with a few mounting elements and paint. Nothing here would stop the function of the system, only the fit might be off if the maker wasn’t careful in their measurements.
A display is electrically active as such there can be issues. But as far as Malware or Spyware being injected into the display, someone gave you a tall story! The display (LCD) can’t be infected as such. The LVDS connection is not able to support the data format and even the DP standards (retina screens) likewise can’t either. The only possible source would be the FaceTime camera, but even that is extremely remote even within a iPhone or iPad.
First generation devices (many years ago) did have risks as the PC world was a much more open not having the fears we have today.
da
Okay thanks for unwinding that lol. My mistake. Thank you so much :) I have purchased the part and will be installing soon.
When I said "display" I still meant "glass replacement screen" lol. The whole time I only meant "glass replacement screen". Thank you for teaching me a new word! lol...
Just so I am clear:
So, is it possible to hack a phone with a third party iPhone glass screen replacement installed?
da
@gracebear64403 - iPhones use a laminated cover glass/display assembly which is glued together so one can’t replace the cover glass alone. Review the fixit teardown for your exact model here you cabin see what yours is setup.
da
Aggiungi la tua risposta
Grace Bear sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 14
Tutti i Tempi: 365
