Salta al contenuto principale
Le Bose QuietComfort 35 II (numero di modello: 789564-0020) sono cuffie Bluetooth con cancellazione del rumore progettate da Bose. Il dispositivo viene fornito con un caricabatterie USB e un cavo jack cuffie ed è compatibile con dispositivi Bluetooth iOS e Android.
Charging problem - replace Micro-USB connector?
I can't charge the headphones. Is it possible to replace the Micro-USB connection?
Questa è una buona domanda?
Punteggio 1
2 Commenti:
I also have this issue.
With the charger disconnected I see a blue led light of the pairing that is always on.
When I connected the charger to the micro USB connector a red led light starts flashing and the blue led light continues to be on.
I already replaced the battery. I was now thinking on replacing the micro USB connector. Do you have any other idea's?
da Condividi
If you have 2 LEDs, the blue one is telling you it is on and paired. The blinking red one is telling you it is charging. If there was a problem with the connector, the red LED would not be flashing when you plug it in. However, if it is "flashing' (fast blinking) it may be telling you there is a problem with the battery or something internal.
da Condividi
Aggiungi un commento
1 Risposta
Why do you think it is the connector? There are a number of other possibilities including the charger and the battery.
Post any symptoms you have experienced in the past.
Punteggio 0
1 Commento:
I have several chargers.
The problem occurred suddenly without deteriorating battery before.
I can visually see the damaged connector.
da Condividi
Aggiungi la tua risposta
Johan Varland sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 11
Ultimi 30 giorni: 35
Tutti i Tempi: 629
