Salta al contenuto principale
Il Sharp AQUOS LC-32LE185I è un televisore con schermo da 32 pollici. Questo televisore ha una risoluzione HD Ready di 1366 x 768 pixel.
Sharp LC-39LE440M tv
When I switch the tv on, the display screen light turn on white for a few second, then it switching of and I see a black screen. The power led light is green, showing there is power to the tv. What causes the display screen to go dark. Could it be the backlight led faulty.
Thanks,
Alvin
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
Hi @alvintan9,
Is the sound still working when the TV is on but the screen is black?
If so try shining a flashlight at an angle close to the screen and check if you can see any images at all on the screen.
They will be very faint if they are there.
If you can see images it may be the backlights or the mainboard is turning them off for some reason.
If there are no images and no sound either its seems like a mainboard problem.
Punteggio 2
1 Commento:
sound working screen no
da
Aggiungi la tua risposta
alvintan9 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 17
Tutti i Tempi: 678
