Salta al contenuto principale
Processore dual-core da 1,6 o 1,8 GHz, 2 GB o 4 GB di SDRAM, SSD da 64 GB o 128 GB
Internal Storage not Detecting Full Capacity
The title sums up the issue. I dragged my old Macbook out of storage, tried to boot it up and it didn't detect an OS. I figured it would be an easy fix, booted it into recovery mode, and went to reinstall OS-X. The installer did not detect a drive that it could install to so I went into Disk Utility from recovery mode and disk0 with Mac OS X Base System is listed, with only 1.19 GB total storage. Clicking "Erase" does not let me do anything, nor do "First Aid" or "Restore". Mostly wondering if I can fix this somehow or if the drive is probably dead.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta più utile
Replacement drives for this model have dropped in prices. I'd drop a new one in, here's how to do it:
Sostituzione SSD MacBook Air 11" metà 2011
Punteggio 1
3 Commenti:
Are there any other possible solutions? I don't really want to spend the money on a drive if I can avoid it, as I don't really care about the laptop to begin with.
da
If it were in my shop, I would hook it up first to an external drive with an appropriate operating system installed using a USB adapter and see if it boots. But I don't know what you have available.
da
The laptop does boot Linux Mint and Arch Linux, but I can't install them since they don't recognize a storage device to install to.
da
Your facing a file system mis-match! The recovery is based on the older HFS+ where as the drive has been upgraded to High Sierra or newer which then converts to APFS.
You’ll need to create a bootable OS installer which is running a newer macOS to then run Disk Utility and you may need to re-install the OS as well.
Punteggio 1
Aggiungi la tua risposta
tmbh21 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 20
Tutti i Tempi: 437
