Salta al contenuto principale
Il Samsung RF24FSEDB è un frigorifero French Door da 665 litri con design a profondità ridotta, finitura resistente alle impronte digitali, sistema Twin Cooling Plus con evaporatori separati, opzioni Power Freeze e Power Cool e illuminazione a LED.
Ice maker no longer working
My ice maker suddenly stopped working. I replaced the filter and the ice maker water valve. The main water supply works fine and the appliance does produce water just not ice. Does anyone know what else the problem might be?
Thanks in advance.
Paul Burnett
Update (08/27/23)
By the way, the model # is RF4289HARS/XAA.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi @paulburnet63747
Here's the fast track troubleshooting sheet for the refrigerator that may help.
Perform the Self Diagnosis check as shown on the first page and check if there are any error codes being displayed.
The error codes and their meanings are shown on p.4.
There's also a Heat Release I/M Test Mode on p.2 which you can try as it checks if the ice maker thermistor, harvest motor and water valve are OK
Punteggio 2
1 Commento:
Thanks for your reply. I'll try these tests and see if they correct the problem.
da
Aggiungi la tua risposta
Paul Burnett sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 3
Ultimi 30 giorni: 12
Tutti i Tempi: 397
