Salta al contenuto principale
Numero modello A1707. Rilasciato a giugno 2017, questo MacBook Pro adotta processori Kaby Lake fino a Intel Core i7 quad core da 2,8 GHz con Turbo boost fino a 3,8 GHz.
Not the typical flex gate problem.Haven't found same problem with mine
The problem is display turns off but backlight still there, keyboard lights up, touch bar is there, and external monitor still displays. It occurs at random (sometimes screen twitches first and then problem occurs). When I close and open the lid the display goes back.
tried resetting PRAM and SMC, problem still there.
tried in safe mode, problem still there.
tried downgrading to Monterey from latest Ventura, problem still there.
I can boot my laptop on any angle.
Not even once I dropped my laptop.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Give this a try, restart the system and press the Shift (⇧) key to enter safe mode. Try using the system this way to see if the display reacts in the same way
Reference: Mac startup key combinations
I’m suspecting the T-CON board which typically sits within the display lid area has failed here. The retina displays have a higher scan frequency so it’s possible the clocking within the T-CON has failed but only the higher one. Running in Safe Mode we are keeping the system at the lower clock rate.
If that works I think that nails it as a T-CON issue.
So unless you can get to an independent repair person with the needed skills and tools to fix the board which is that part that hangs off of the display to get yours working again. Otherwise, it’s a new display assembly! MacBook Pro 15" Retina (Late 2016-2017) Display Assembly following this guide Sostituzione Schermo MacBook Pro 15" Touch Bar 2017
Immagine Replace a display compatible with the model A1707 late 2016 to 2017 Retina 15" MacBook Pro laptop. Includes the 2880 x 1800 15.4" Retina LCD Screen, Display Cover, Bezel, Camera.
Prodotto
$507.99
Punteggio 1
1 Commento:
Tried it just now. Sadly, display reacts in the same way in safe mode. %#*@, new display it is :(( . Thanks for the help!
da
Aggiungi la tua risposta
Glynn II Lumasag sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 91
