Salta al contenuto principale
Informazioni di riparazione e soluzione problemi per l'HP EliteBook 840 G5, un portatile HP facente parte della serie HP EliteBook. Rilasciato a febbraio 2018.
Why my laptop only start when I charge externally or some time interna
When I start my laptop I can't start but after some try I start after 3 or 4 min It automatically switch off sometimes it start when I charge externally but same switch of problem
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi @ixlucifer
Seems like the battery is failing and needs to be replaced.
Does the laptop turn on and stay on if the charger is left connected?
If the laptop stays on, create a battery report to check the status of the battery.
Once you have the report, compare the Design Capacity value versus the Full Charge Capacity value. For a good battery they should nearly be the same.
You can work out the battery status as a percentage by using the formula Full Charge Capacity value x 100 ÷ Design Capacity value.
If the battery needs replacing search online for 933321-855 to find suppliers that suit you best.
Here's the Sostituzione batteria HP EliteBook 840 G5 guide that may help.
Punteggio 1
Aggiungi la tua risposta
IX LUCIFER sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 14
Tutti i Tempi: 256
