Salta al contenuto principale
L'HP Laptop 14-dk1022wm è un dispositivo compatto ed economico, ampiamente utilizzato da studenti e professionisti per la scuola, il lavoro e l'uso personale.
How to upgrade ram
I need a guide on how to get more ram on my laptop
Questa è una buona domanda?
Punteggio 5
4 Commenti
Please give us your exact make and model number. Your current RAM configuration might also help. Thanks
da
My laptop very slow run
da
How to upgrade my Ram
da
@akanickaisteve
Please confirm the full model number of your laptop as shown on the product label on the bottom of the laptop?
da
Aggiungi un commento
1 Risposta
Risposta più utile
Without knowing much, I can tell you this: It's usually a matter of removing the bottom cover, but the "-wm" version usually only has one RAM slot unless they sport a decent processor like an i5; if you have a Pentium or i3, the board probably only has one RAM slot. While it's rare, it happens; some of these also use soldered RAM but that's not the case outside of known troublemakers like the HP Stream 11 was, at least. The Stream 14 usually uses a single DIMM.
Punteggio 4
Aggiungi la tua risposta
Darren Aizebeokhai sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 19
Tutti i Tempi: 1,180
