Salta al contenuto principale
La versione più piccola ed economica del decimo telefono di punta Galaxy di Samsung, rilasciato a febbraio 2019. Distribuito con Android 9.0 (Pie).
charging light is blinking
Charging notification light blinks instead of the charge volt indicator. What up with that? I replaced the original battery today myself. What is that supposed to be doing?
Questa è una buona domanda?
Punteggio 0
2 Commenti:
Hi @msmsmak,
Does the blinking stop after sufficient time in your estimation has elapsed to fully charge the battery?
If it does, does the phone turn on with a display OK when the charger is connected?
da
It only blinks when its connected to charger. Screen is operating normally otherwise. Battery care setting shows normal. I did notice that the rear cover is nominally cracked.
da
Aggiungi un commento
1 Risposta
Make sure the back cover and all parts are reassembled before trying to charge, some Samsungs won’t charge if it detects the cover isn’t seated properly.
Punteggio 0
Aggiungi la tua risposta
MsMsmak sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 22
Tutti i Tempi: 317
