Salta al contenuto principale
Informazioni su riparazione e smontaggio del portatile ProBook 440 G7. Questo portatile business da 14 pollici è stato prodotto nel 2020.
Why is my laptop beeping continuously?
I tried to turn on my laptop and found my laptop beeping continuously.What should I do to fix it?
Questa è una buona domanda?
Punteggio 1
4 Commenti
Hello, are the beeps in a sequence by chance, or is it just one long beep? If it is a sequence if you could count the beeps and reply that would be great!
da
No it's actually beeping like a car's blinker
da
Could you possibly record it and add it to the post?
Not sure how?:
Aggiungere immagini ad una domanda
da
The beeps could indicate a fault. The number of beeps, as BurtBen suggested a recording, might help us diagnose the issue.
How old is the laptop?
da
Aggiungi un commento
1 Risposta
Risposta più utile
You should try checking with this HP guide. Your problem might vary from a dead CPU, to a simple reset. I've had similar issues with some Lenovo machines and the issues was solved with a simples reseat of the RAM. Good luck.
Punteggio 1
1 Commento:
None of them helped
da
Aggiungi la tua risposta
Jackson King sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 18
Tutti i Tempi: 514
