Salta al contenuto principale
Il Lenovo IdeaPad 1-11ADA05 è stato lanciato il 28 gennaio 2022. Il Lenovo IdeaPad 1-11ADA05 è un portatile entry-level da 11,6 pollici rilasciato nel 2020, progettato per studenti e utenti occasionali. Esegue Windows 10 o Windows 11 in modalità S ed è dotato di un processore AMD Athlon Silver.
Laptop keyboard not working
The laptops key is not working any of the key not working
Questa è una buona domanda?
Punteggio 2
1 Commento:
Hi @hmmbujhi,
Have you checked that the laptop is not in tablet mode, i.e. touchscreen keyboard works but the physical keyboard doesn't?
Has any liquid been spilled on the keyboard at all?
da
Aggiungi un commento
1 Risposta
If none of the keys on your laptop are working, it could indicate a hardware or software issue. Here are a few steps you can try to troubleshoot the problem:
  1. Restart the Laptop: Sometimes, a simple restart can resolve temporary glitches. Restart your laptop and see if the keys start functioning again.
  2. Check for Physical Damage: Inspect the keyboard for any physical damage, such as spilled liquids or stuck keys. If you notice any damage, you may need to consult a technician for repairs or consider replacing the keyboard.
  3. Check the Keyboard Settings: Ensure that the keyboard settings on your laptop are correctly configured. Go to the "Control Panel" or "Settings" menu and check the keyboard settings. Make sure the correct language and keyboard layout are selected.
  4. Update Keyboard Drivers: Outdated or incompatible keyboard drivers can cause keyboard malfunctions. Visit the manufacturer's website and download the latest drivers for your laptop model. Install the updated drivers and check if the issue persists.
  5. Connect an External Keyboard: If possible, connect an external USB keyboard to your laptop and see if it works. If the external keyboard functions correctly, it suggests a problem with the laptop's built-in keyboard.
  6. Run a Virus Scan: Malware or viruses can sometimes interfere with keyboard functionality. Run a comprehensive scan using reliable antivirus software to ensure your system is clean.
  7. System Restore: If the issue started recently and you suspect it may be related to a software update or installation, you can try performing a system restore to a previous point when the keyboard was working correctly. This can help revert any system changes that might be causing the problem.
  8. Seek Professional Help: If none of the above steps resolve the issue, it is recommended to seek assistance from a professional technician or contact the manufacturer's support for further troubleshooting and guidance.
Punteggio 0
Aggiungi la tua risposta
Hmm Bujhi sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 6
Ultimi 30 giorni: 16
Tutti i Tempi: 892
