Salta al contenuto principale
Il Toshiba Satellite L50D-B è un computer portatile venduto come parte della linea di computer Satellite.
How to remove the internal SSD?
The internal SSD is not using the normal SATA connection, I have the backplate off. There are rubber corners around the SSD too.
Update (05/28/23)
Immagine
. Photo
Questa è una buona domanda?
Punteggio 0
1 Commento
I added a photo but I am unsure if it posted.
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
You should be able to just slide it out as shown in the attached picture. After you pull it out, you may find that the drive really is a SATA drive, just connected in a wonky connector. I was taking apart a laptop the other day that had a ribbon cable attached to an adapter that attached to a SATA connector on the drive. Just give it a go and let us know how it goes.
Good luck!
Immagine
Punteggio 1
2 Commenti:
That works thanks!
da
You're very welcome! I'm glad my tinkering was able to help someone! :)
da
Aggiungi la tua risposta
SaltyAsterisk sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 2
Ultimi 30 giorni: 13
Tutti i Tempi: 428
