Salta al contenuto principale
Riparazione e informazioni aggiuntive per il frigorifero GE GFE26JGM****, un frigorifero con sbrinamento automatico senza fabbricatore di ghiaccio né distributore sullo sportello, disponibile per la prima volta nel 2019. Questa pagina copre le informazioni per i numeri di modello corrispondenti alla serie GFE26JGM****.
Wiring connector assembly help
Removed the doors, while disconnecting the harness, the connector came off. The color of the wires don't match. We need help matching the wires back up
Black/yellow, white, 2 white/blue
Black yellow, white, red/white, gray/white
Update (05/05/23)
Immagine
Immagine
Update (05/05/23)
  • trying again
Immagine
Immagine
Update (05/05/23)
GFE26JGMWFBB is the model
Questa è una buona domanda?
Punteggio 1
3 Commenti
can you add photos
da
@dougwilds i can't see them doug it just says image
da
@dougwilds pictures can only be added to Question or Answers , not comments. It's fixed :-)
What make and model is this?
da
Aggiungi un commento
1 Risposta
Risposta più utile
Hi @dougwilds
I can't find the mini manual (GE part #31-1000533) for a GFE26JGMWFBB but there are two models which are very close, i.e. GFE26JGMAFBB & GFE26JGMNFBB.
Unfortunately they have different mini manual part numbers not only from your model but from each other as well. Maybe there are slight variations in the wiring due to them having different features perhaps
At least they show the connections and colours of all of the wires used
GFE26JGMAFBB (31-1000396)
GFE26JGMNFBB (31-1000474)
Using an Ohmmeter, you may have to identify the wires by colour back to the main board connector pins, by looking at either of the manuals to see if one is appropropriate.
Hopefully one will be and then once you know where they connect to on the mainboard, use that manual to see where they go to and what colour wire they connect to or end up as.
Hopefully this is of some help.
Punteggio 2
Aggiungi la tua risposta
Doug Wilds sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 15
Tutti i Tempi: 597
