Salta al contenuto principale
Informazioni di riparazione e guide per l'Apple iPhone 5c annunciato il 10 settembre 2013. Modello: A1532, A1456
iPhone stuck on boot loop...
i replaced the front camera, then the screen started to glitch, so i tried resetting the phone.. it kept freaking out and about halfway through the restore on itunes it will just force shut down. every single time it will stop restoring at about 512 megabytes and then i tried using 3utools. well, it got stuck at about 11% before shutting itself down completely every single time also
also, i should mention flashing has been successful before, so this is weird...?
help?
Questa è una buona domanda?
Punteggio 0
1 Commento:
disconnect the front camera to see if theres any change
da
Aggiungi un commento
1 Risposta
have you tired a new battery or updating the phone also try this with out the front camera connected if possiable
Punteggio 0
Aggiungi la tua risposta
timtom77 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 12
Tutti i Tempi: 168
