Salta al contenuto principale
Informazioni di riparazione e guide per l'Apple iPhone 5c annunciato il 10 settembre 2013. Modello: A1532, A1456
thermal paste under battery?
Immagine
well, i used a heat gun on this phone to remove the battery... and i notice something sliver under the battery... and the adhesive tab didn't budge (and ended up ripping)
Immagine
Immagine
yeah it was kinda hard to see, but still is this normal...?
is this just the base but damaged?
edit its not... it crumbles when you get something under it.. could it maybe be thermal paste....?
Questa è una buona domanda?
Punteggio 1
26 Commenti
There shouldn't be any thermal paste under there. it would be useless. Any chance you poked through the battery/tore it?
da
@oldturkey03 more than likely the inside of the battery
da
@tech_ni that is what I was thinking. The crumbling would make me think it is :-)
da
@oldturkey03 did know people still bought 5c, i binned about 8 housings with parts
da
@oldturkey03 won 2 items on ebay today for repair, iphone 8 no power for £8.50 and a gopro hero 8 for £17.50 with no power
da
Mostra 21 altri commenti
Aggiungi un commento
1 Risposta
Soluzione prescelta
Could be the old adhesive. Seems to be in the right place. If the tabs break off I either use a heat mat and a spudger to gently lift the battery or put some alcohol down the side of the battery and tilt the phone so it runs over the adhesive.
Punteggio 2
Aggiungi la tua risposta
timtom77 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 10
Tutti i Tempi: 477
