Salta al contenuto principale
Aggiornamento del BlackBerry Bold originale. Conosciuto in alcuni ambienti come BlackBerry Bold 2.
Water Repair Bold 9700
How I Can Repair A Water Damage?
Questa è una buona domanda?
Punteggio 1
1 Commento
most likely you will need a new battery, once you have cleaned the phone I'd buy a new battery and then see what if anything works, get back to us.
da
Aggiungi un commento
2 Risposte
Soluzione prescelta
Guillermo Eirin, I would start by disassembling the phone and cleaning it. Use this as a general guide. You can find a teardown for your phone right here. There is also a take apart guide on here. . Hope this helps, good luck.
Punteggio 2
Shake and wipe water off , open phone and wipe parts (try with a non static cloth ) put phone in a bowl of rice for a couple of minutes(30) that will take out extra water if next day it does not come on get a new battery and see if problem continue if it does get a new phone .
Punteggio 0
Aggiungi la tua risposta
Guillermo Eirin sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 12
Tutti i Tempi: 2,391
