Salta al contenuto principale
Sistema Home Theater 5.1 da 1000 watt di potenza totale del 2018. Include un lettore Blu-ray, Wi-Fi integrato e connettività Bluetooth per un facile streaming di musica e video.
Micom Options are lost
My hometheater not working properly. I figure out micom Options are lost. All the op0, op1.. to op5 are 00. Is there anyone who has these codings. Of you have the device you can see the options through (NO DISC or Tray OPEN State) and Setup-DISPLAY-TV Aspect Ratio16:9 Full 4+5+6+2 +5+8+0 +ENTER
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta più utile
Hi @sercantaylan
Have you tried a power refresh?
Turn off the home theatre if it is on, disconnect the power to the home theatre and then press and hold the Power button for a full 30 seconds and then release it. Reconnect the power to the device, turn it on and check the settings
If no good, try contacting the LG customer service centre in your location (ask for tech support) and ask if the latest software version is available for your model home theatre, either as a download link or an emailed file
If they state that you can update online using the settings in the device (Settings > Others> Software > Update) tell them that there are no settings available and that you can't do this.
Also if there is software available ask how to install it manually.
Just what I'd try
Punteggio 1
1 Commento:
I have updated but no change. I think the update doesn't make any change on eeprom :(
da
Aggiungi la tua risposta
Sercan Taylan sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 11
Tutti i Tempi: 321
