Salta al contenuto principale
A LED bulb 230V is a type of light bulb that uses Light Emitting Diodes (LEDs) as a source of illumination and is designed to operate at a voltage of 230 volts. This type of bulb is commonly used in areas with higher voltage electrical systems, such as in Europe and other parts of the world that use 220-240V AC power.
3 Domande Visualizza tutte
Switching on the bulb
My washroom's bulb always blinks several times before comes to proper working condition. So what is the reason behind this?
Questa è una buona domanda?
Punteggio 2
3 Commenti
Hi @muhammedsa33137,
Please verify the type of bulb e.g. Incandescent, CFL (compact fluorescent), Fluorescent tube or LED.
da
It is an LED bulb.
da
My bulb is not working what i do?
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
@muhammedsa33137 take a look at this teardown LED Light Bulb Teardown It will show you how to get into one of those and this one LED Birne Lampe 230V E27 defekt reparieren will show you how to check and possibly repair the bulb. Let us know if you need more assistance with that and you can always post images of your bulb components and circuit board with your question. Aggiungere immagini ad una domanda
Immagine iFixit
Guida
Difficoltà:
Molto facile
2 - 5 minutes
Immagine LED Birne 230V LED
Guida
LED bulb lamp 230V E27 defective repair
Difficoltà:
Moderato
30 minutes
Guida
Difficoltà:
Moderato
Punteggio 2
Hi @muhammedsa33137
It may be that the electronic components in the LED light are beginning to fail. Usually it is the capacitors in the light as they may fail prematurely due to the heat generated by the operation of the LED light.
It could also be that the light is loose in the light fitting, making for a poor electrical connection
Punteggio 1
Aggiungi la tua risposta
Muhammed Saad Islahi sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 524
