Salta al contenuto principale
Rilasciato nel gennaio 2018, il ThinkPad T480s è una versione sottile del T480 dotata del tradizionale trackpoint e del trackpad a tre pulsanti.
Computer does not detect the Wifi/Bluetooth module
Hello, I have an issue with Lenovo ThinkPad T480s Wifi and Bluetooth.
The computer does not detect the Wifi/Bluetooth module, there is nothing under Device Manager even when I turn the "Show hidden devices" option. The computer has a fresh installation of Windows 11.
What I have tried so far:
  • Manually install all of the necessary drivers
  • Reset BIOS by disconnecting the battery and CMOS (Wifi is enabled in BIOS)
  • Move the Wifi/Bluetooth module to another T480s that also has a fresh installation of Windows 11 (It works fine on another computer)
I'm not sure what other steps I could take to diagnose the issue, do I just assume there is an issue with the motherboard? Thanks for any help.
Update (03/17/23)
Thanks to @jayeff I was able to identify the issue. I was about to check the voltage as it was suggested but found that there were missing multiple components so the wifi module was definitely not getting 3.3v. Since I don't do soldering I will bring it to the repair shop.
Image from good t480s (with working Wifi/Bluetooth)
Immagine
Image from current t480s (with no Wifi/Bluetooth)
Immagine
Questa è una buona domanda?
Punteggio 0
2 Commenti
@nokia3310 Hi. Were you (or the repair shop) able to fix the issue with the PD9 diode? For some reason, I'm having the same problem with the same laptop model. I don't even understand how it happened in the first place (my PD9 diode is interrupted in the middle, similar to yours).
da Condividi
@milanzazrivec I decided to sell it as a laptop with defect instead of bringing it to the repair shop, since repair shops in my area charge a lot for soldering jobs.
da Condividi
Aggiungi un commento
4 Risposte
Soluzione prescelta
Hi @nokia3310
Try running the Lenovo troubleshooter (click on Network) and check what it shows.
Also maybe check what BIOS version is installed (for latest version, click on Operating System > Win 11 64-bit) and also check what the BIOS version is in the other laptop where the WiFi card works OK with Win 11.
Was the WiFi working OK in the laptop, before upgrading to Win 11?
You could always check if there is 3.3V DC on pin 2 & pin 4 of the WiFi M.2 socket. No power = no WiFi.
Here's an image from the schematic showing the WLAN M.2 socket wiring and the source of the WLAN power supply VCC3WLAN, component PQ15
Immagine
(click on image)
Punteggio 3
1 Commento:
@nokia3310
For that many components to be missing, it seems very specific to not wanting WiFi/BT capability in the laptop for some reason,
da Condividi
first make sure airplane mode is off then if it is try uninstalling the old drivers n download new and updated ones. sometimes your computer might just want you to update your software
Punteggio 0
1 Commento:
This is not helpful, since I specified that it's a fresh installation of Windows and I already tried installing all of the necessary drivers manually. As for airplane mode, since the computer does not detect Wifi/Bluetooth module the Airplane mode function is greyed out and you cannot click it. Also, when I was testing Wifi/Bluetooth module, I moved it to another T480s that has exactly the same setup - a fresh installation of Windows 11. And it worked there, indicating that this couldn't be a software/driver/module issue.
da Condividi
Well for Bluetooth you can do select Start > Settings > Devices > Bluetooth & other devices > Add Bluetooth or other device > Bluetooth. Choose the device and follow additional instructions if they appear, then select Done.
And if this not working than check for the outdated driver as well because some time an outdated driver can also cause these kind of issue in you system.
And for wifi related issue you should check out this it will be very helpful for you: https://support.microsoft.com/en-us/wind...
Punteggio 0
I had the same issue, and I believe the problem lies in the opening process. The missing components are located very close to the edge of the bottom cover, and if you use something—even plastic tools like those from iFixit—to pry it open in that area, you can easily knock off one of those tiny components. In my case, just one part is missing, but that’s enough to prevent the network card from getting power.
So, be careful when opening your T480s, especially on the oposite side of the fan openings!
Easiest fix is to sacrifice one USB A port to use a usb wifi adapter like the TP Link Archer TX10UB Nano. It's small enough to remain in the machine at all times.
Alternatively, there might be an adapter to replace the wan card (if still functional) with the wifi adapter
A Question: Was the repair shop able to fix it? How much was it?
Punteggio 0
Aggiungi la tua risposta
Nokia3310 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 16
Ultimi 30 giorni: 55
Tutti i Tempi: 1,986
