Salta al contenuto principale
La DYMO LabelWriter 450 è una stampante per etichette di qualità professionale per uso domestico e in ufficio. Numero di modello: 1750283
How do I replace ink cartridge?
Black ink is running low and not sure how to get to it to replace it?
Questa è una buona domanda?
Punteggio 0
3 Commenti
Hi @keithpl,
Please verify the make and model number of the device that your question is about.
The Dymo LabelWriter 450 doesn't use ink. It is a thermal printer. The printer uses heat from a thermal print head to print on specially treated, heat-sensitive labels
da
I have a Dymo LabelWriter 400 Turbo, do I need to replace the ink cartridge or is there no ink on this model too?
da
@brenda27832
All 400 series Dymo LabelWriters are the thermal print type i.e. no ink
da
Aggiungi un commento
1 Risposta
Risposta più utile
This is a termal printer, it does not use ink or toner, chances are your battery needs charging or replacing.
Punteggio 1
2 Commenti:
Why do I need a battery for the thermal printer if it has an electrical plug?
da
@gailstewart You are correct that the LabelWriter series are all corded. Are you having the same problem as the original question, of the printing fading out?
da
Aggiungi la tua risposta
Keith sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 11
Ultimi 30 giorni: 44
Tutti i Tempi: 2,493
