Salta al contenuto principale
Piccole macchine da caffè automatiche di Melitta. Queste guide possono essere utili anche per altri modelli Melitta e per le macchine da caffè automatiche di Nivona, Siemens e Miele, poiché i modelli hanno una struttura simile.
Size of the grind
Hi,
I opened the Caffeo Solo for a cleanup and closed it back. Now when the motor grind, the size of the coffee grind is top big and the infusion is not happening. I tried to change the size of the grind, nothing changed.
Thks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Did you open the grinder? Follow this guide, open it and adjust it. This is a good opportunity for a replacement of the grindstones.
Punteggio 1
5 Commenti:
Thks for the quick answer ! I'll try next weekend and let you know.
da
I followed the tutorial but nothing changed. The size of the grind is still too big. I didn't see where to adjust so it might be that.
da
I don't know why, but this part does not appear in the english translation:
Sostituzione delle macine Jura
da
If you want to watch the grinder, when opened, use an empty toilet roll.
da
I finally had time to unmount it and managed to fix it. The issue was that I did not screw properly the black ring (size selector) to the grinder. Thank you very much for your help.
da
Aggiungi la tua risposta
Romain sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 17
Tutti i Tempi: 940
