Salta al contenuto principale
Il Meta Quest 2 (ex Oculus Quest 2) è stato lanciato a ottobre 2020 ed è il successore dell'Oculus Quest.
plastic head strap holder broken
The thin black piece of plastic that holds the top of your head strap broke when i put it on, and now i only have the side pieces, is their a head strap that i can use that doesn't need that? and / or how do i fix the plastic piece
Questa è una buona domanda?
Punteggio 4
2 Commenti
My dog chewed the speaker part of my quest where the strap connects to how would I fix this and is there a way to take it off
da
mine did too, did you guys figure out how too do it?
da
Aggiungi un commento
3 Risposte
Risposta più utile
Program post some pictures of what the broken parts look like.Aggiungere immagini ad una domanda
Maybe we can come up with a way of fixing it, maybe you need to replace the strap. To work on it, check something like this video or this guide Sostituzione cinturino Meta Quest 2
Immagine iFixit
Guida
Difficoltà:
Molto facile
2 - 5 minutes
Immagine Meta Quest 2 Cinturino
Guida
Difficoltà:
Molto facile
1 - 5 minutes
Punteggio 1
Buy a replacement on a website
Punteggio 0
Oculus Quest 1 and Quest 2 Faceplate Head Strap Mount
https://www.etsy.com/listing/814729613/o...
or...
An easy at home repair if you’ve broken your headstrap recently.
https://www.tiktok.com/@fixmyoculus/vide...
https://www.fixmyoculus.com/s/shop
Or...
Simple and effective fix for broken head strap support
https://www.reddit.com/r/oculus/comments...
Punteggio 0
Aggiungi la tua risposta
Program sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 32
Tutti i Tempi: 3,917
