Salta al contenuto principale
Uno smartphone prodotto da Samsung con sistema operativo Android 6.0 SoC Qualcomm Snapdragon 430 Octa-Core a 1,4 GHz Display da 5" con risoluzione 1280x720p 16 GB di memoria interna (espandibile)
The process com.android.phone has stopped
This error keeps coming up when I press OK it comes back constantly even after clearing data for the phone app how do I fix this without reseting it?
Questa è una buona domanda?
Punteggio 1
2 Commenti
I have a ONN tablet,no phone yet I get this message all the time
da
@sandratibbetts It actually doesn't matter what device you're using, whether it's a tablet or a phone; what they have in common is the Android operating system, which is where your software error is coming from. Does your tablet have a slot for a SIM card?
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
If you see the error message “Unfortunately, it has stopped
process.com.android.phone
or unfortunately stop
com.android.phone
Process after installing ROM
If you are new or update your firmware, there are actually several ways to fix it
The error message is triggered by phone or SIM toolkit app
So, if you are constantly getting the “Unfortunately, the process com.android.phone has stopped” error.
Punteggio 1
2 Commenti:
Solution #1: Disable automatic date and time
This simple setting change can help you remove the error message for good. To change this, go to Settings from the Home screen, then tap
da
Second solution: Clear data and cache
Third solution: Clear data and cache
Boot the device in Safe Mode
da
Aggiungi la tua risposta
80stechkid sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 21
Ultimi 30 giorni: 76
Tutti i Tempi: 1,103
