Salta al contenuto principale
2.26 or 2.4 GHz / White plastic unibody enclosure
Won't boot, continuous beep synchronize withe flash of light
I have a macbook and it was spilled by water. Before there were no display on the screen, the light on the charger didn't also have a light. totally dead.
After i dissembles it and clean some part of alcohol and back every pieces of it, the light on the charger comes to green to red and then there is a sound of continous beeping which is synchronize to the flash of light on the right side.
what would be the problem now with my macbook? please help me with my situation. thank you so much!
Questa è una buona domanda?
Punteggio -1
2 Commenti
i already bought a new RAM, but still it won't work. I will try to clean the slots of RAM. Thanks for the advice remacberlin. I will try it later.
da
HERE IS THE ATTACHED VIDEO FOR MY PROBLEM...
http://www.youtube.com/watch?v=EPuZMim56...
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The beeping/blinking should indicate that no RAM is found. Maybe the RAMs are fried. Take a good look at the RAM slots, clean if neccesary and reseat and try again.
Punteggio 3
2 Commenti:
Here is the video of my MacBook for better analysis.
We can also observed that without pressing the power button it turns ON by itself.
Thanks for your quick respons.
da
I had the same problem with a macbook 1181 this morning. One ram stick was faulty. Replacing the stick with a working one solved the issue.
da
Preparati per le riparazioni future
Acquista tutti
Aggiungi la tua risposta
Freddierick sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 6,911
