Salta al contenuto principale
The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
DiskUtility doesn't read new SSD with adapter
Hello,
I have A1466, with motherboard 820-3437-B.
I tried to install a new SSD for more Storage, but the disk utility doesn't read anything (tried with "utildisk list" too), I used 2 different SSDs:
I tried even more adapters:
I get the same results with different products, i have to specify that the old (original SSD) is still functioning, and when I plug it the disk utility recognize it immediatly.
I even tryed with an USB adapter, and with that it WORKS, I mean from disk utility I initialized the disk and even installed the macOS, which works perfectly fine with the USB adapter.
Anyone knows how and why my motherboard doesn't read the "adapter/ssd"?
Thanks
Questa è una buona domanda?
Punteggio 0
1 Commento:
What is the OS-X/macOS you have on your current drive and how are you trying to setup the drive from within Internet recovery?
da
Aggiungi un commento
1 Risposta
First you are trying to use a M.2 SSD with an adapter as Apple SSD are custom to them. These SSD’s and adapters have issues!
I would use the proper SSD or use one that has been designed from the ground up like either OWC or Transcend drives.
Punteggio 0
4 Commenti:
well of course that was the easiest way, but it costs a lot, i checked online and a lot of people didn't have any problem with the adapter, but i don't get why mine doesnt work
da
wow leggion - Again, how are you trying to setup the drive, what is your system’s OS version?
Sometimes going cheap is more expensive in the long haul, I’ve pulled out quite a few of these as they don’t hold up.
da
the recovery system OS is OS X Maverick
da
Then you are fighting the older file system (HFS+) vs the newer file system the system is expecting (APFS).
You can’t use Mavericks as it doesn’t know how to boot up under APFS which is how you setup the SSD.
da
Aggiungi la tua risposta
wow leggion sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 193
