Salta al contenuto principale
Informazioni di riparazione e smontaggio per il televisore UHD Samsung da 55" con numero di modello UN55MU6290xxxx. Rilasciato nel 2017.
What does this mean
Smart curved tv has a purple patch in the middle, appear while tv was working fine, have unplugged and plugged again. The Smart Tv logo pops out clearly and starts to discolor with purple, can it be fixed.?
Questa è una buona domanda?
Punteggio 0
2 Commenti
Milka Rocha most commonly an issue with the backlight. We would have to see what your screen displays. Post some pictures of it with your QUESTION Aggiungere immagini ad una domanda
da
it’s been diagnosed by professionals as a flaw with the LED driver board, which is often uneconomical to replace.
da
Aggiungi un commento
1 Risposta
Risposta più utile
Hi Milka,
I can't give you a diagnosis, but a very similar thing happened to a Samsung flat screen I had. In my case the splotches were blue, but it sounds very familiar. Here's a picture from mine (ignore the white dots on the left side - those are reflections from the Christmas tree).
Immagine
The spots started out as a single spot that got bigger over time, and others started appearing as well. Fortunately for me, mine was still under warranty so I got a replacement. The old one is now in the garage at my son's house, used for workout videos. It still works and the spots eventually stopped growing, but they're still there.
The upshot is that the Costco Concierge service determined the TV wasn't repairable and authorized a replacement, so I'm afraid that doesn't bode well for yours, assuming it's the same problem.
Hopefully someone with more specific expertise in the area of television repair can add their considered opinion.
If you were to add a photo of your TV showing the problem, I'm sure it would help with diagnosing the problem.
Punteggio 1
Aggiungi la tua risposta
Milka Rocha sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 1
Ultimi 30 giorni: 9
Tutti i Tempi: 291
