Salta al contenuto principale
Il Lenovo ThinkPad L460 è un portatile aziendale da 14 pollici rilasciato nel gennaio 2016. Presenta una struttura resistente, un design nero opaco e un TrackPoint rosso al centro della tastiera. Pesa solitamente circa 1,9 kg, è dotato di un processore Intel Core di sesta generazione e di funzionalità di affidabilità. È adatto sia per l'uso aziendale che per quello didattico.
Problem with screen or motherboad?
My lenovo T460 has no 3.3V and no other voltages on screen controller board (CON) except the 20V on the connector and in a big coil. Also no backlight and no picture. Is it possible to have fry anything in main motherboad ? (My hdmi output working normally with my external monitor).
Initially I changed the screen cable, because my screen was changing colors and making vertical shades with freezing picture, especially when the lid was moving.
Initially the problem seems to had be solved ,but after 5 min the problems return, so I opened the screen and begun probing on the CON for voltages and any defect cups and at that time the backlight and the picture was on, with the defects showing..
Now it's only a black screen.(with working hdmi output to TV)
The question is how do I know that I haven't done anything wrong with the motherboard, while I was probing the screen con board ? The 3.3V and other voltages are coming from the motherboard though the screen cable or from the lcd controller board?
Where could I have to start searching ?
I Appreciate your time
Questa è una buona domanda?
Punteggio 2
1 Commento
Mine has no display but shows charging light and power light
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi @metachaos
Couldn't find a schematic for a T460 but found one for a T460s (Compal NM-A581 motherboard) which shows that the backlight power is supplied via fuse F6 on the motherboard and goes to pins 27 & 28 on the LCD connector.
If the fuse is blown it is a 3A_32V_ERBRD3R00X.
If there is no power on either side of the fuse, the power comes from Q1 (TPCF8002_2-3U1A)
If there is power on the pins then then backlight is turned on and off in the screen by a backlight enable signal sent on pin 18.
Here's the schematics that may help you further, (scroll down to the download link). Go to p.38 to see the pinout for the LCD cable connector.
Punteggio 2
Aggiungi la tua risposta
Lord Chaos sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 9
Ultimi 30 giorni: 40
Tutti i Tempi: 1,136
