Craftsman 917 riding mower won't stay running
I just put in a new battery. The mower starts fine. When the clutch is released, the mower stalls. Any solutions?
Questa è una buona domanda?
Ottieni un rapido accesso alle guide, ai componenti e alle risposte per i tuoi dispositivi
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 434
Are you saying that when the clutch is disengaged the motor shuts off?
da Len
@pcahill doe sit stall when you increase the throttle to rev the engine higher? If not then it is most likely not the fuel supply. If it does it could be a carb issue. I would check the safety switches for function i.e. continuity and wiring.
da oldturkey03
