Salta al contenuto principale
La sesta generazione della Subaru Legacy ha fatto il suo debutto al Chicago Auto Show del 2014 ed è entrata in produzione per l'anno modello 2015.
check engine light on code p700.
i got this check engine light everytime it rains . i scan the code and it show p700 . ( transmission failure ) however the car run okay no problem and after 2 days of doing running the check engine light will turn off.
Questa è una buona domanda?
Punteggio 1
1 Commento
See if the diagram here helps. It's from the Outback Owners site.
https://www.suoutback.com/transmission_h...
da Condividi
Aggiungi un commento
1 Risposta
Soluzione prescelta
It could be a number of issues but when you said it mainly happens when it rains then i would put money on it being a bad connection in the wiring harness to the transmission. Maybe water causing a short circuit & then once it’s dried out the transmission control unit thinks the fault has cleared.
I would follow the wiring harness from the left side of the dash, through to the gearbox. Checking for any breaks in insulation & also the security of any connector blocks outside of the interior of the vehicle. I know the Subaru Forester has 2 BIG connector blocks on the top of the gearbox around the bell housing area. It maybe the problem lies in those. Google your transmission wiring harness & see what the photos show you.
Good luck
Punteggio 1
Aggiungi la tua risposta
EDWIN CHAN MENCIAS sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 34
Tutti i Tempi: 670
