Salta al contenuto principale
Il Super Nintendo Entertainment System (SNES), o semplicemente Super Nintendo, è una console videogame a 16 bit pubblicata da Nintendo nel 1990. Il Super Nintendo è stato uno dei best seller del suo tempo e ha ancora oggi una vasta fanbase.
No Power Issue SNES
My SNES has stopped working, measuring the output of the power cord, the max I got was 1 volt, does this mean it is the power cables fault? This all started when the console fell, so I have checked the insides of the console and the charger, the console looked completely fine on the inside. I tried to measure from the chargers transformer itself but I don’t know which parts to put my prongs on. Most likely I think it’s the cable, I don’t think it’s the power connector itself, I have measured around the same voltage on the console itself that I did on the power cable. On Continuity mode, I put one prong on one of the power prongs, one on the other side of the cable, no beeping.
Immagine
Immagine
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
We have found that this issue can be caused by using an underpowered AC adapter or power source. The problem can be resolved by using a licensed AC adapter. You can purchase one from the Nintendo Store. If a licensed AC adapter is unavailable, you can try using a different AC adapter that is rated as 5V/1A. Now i am sharing this helpfull answer No Power Issue SNES- apkbik
thanks
Punteggio 0
Aggiungi la tua risposta
Connor Steffenhagen sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 13
Tutti i Tempi: 987
