Salta al contenuto principale
L'aggiornamento di Marzo 2015 della linea 13" dei Macbook Pro con Retina Display (modello A1502) adotta processori Intel Core i5 ed i7 di quinta generazione, introduce inoltre il trackpad Force Touch.
20 Domande Visualizza tutte
2015 13 MacBook Pro Battery Drain during sleep
For some reason the battery on my computer is draining heavily during sleep for some reason. I already tried reinstalling Big Sur but the battery is still draining. I even got a new battery and it’s still draining. Can anybody help me with this?
Running Big Sur latest version clean installed.
Logs linked here
https://pastebin.com/VPbLkEHN
Questa è una buona domanda?
Punteggio 0
5 Commenti
@jimmysofat6864
Can you verify its turning off,
try to see if the fan is spinning near the vents
da
@beanman56 Yes I can tell the fan has shut off. Actually most of the time the fans aren't even on and only spin up when something intense is going on.
da
@jimmysofat6864 - Lets check the battery, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Aggiungere immagini ad una domanda
da
@danj I just added it right now.
da
hmmm idk why then
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Well this battery is 5 1/2 years old! While the cycle count is very low with only 4 cycles, the batteries chemistry doesn’t last indefinitely! I’m suspecting this system is always on the charger so it doesn’t run through cycles like most other laptops do.
Bottom line its time for a new battery MacBook Pro 13" Retina (Early 2015) Battery and here’s the guide Sostituzione batteria nel MacBook Pro 13" Retina Display versione inizio 2015
Immagine Replace a 6600 mAh battery compatible with MacBook Pro 13" Retina (Early 2015). 74.9 Watt Hours (Wh), 11.42 Volts (V).
Prodotto
$79.99
Punteggio 1
9 Commenti:
The battery in this laptop was just replaced at a third party but I think they either used old cells or the battery board has a modified firmware that reports back as being manufactured in 2016.
da
@jimmysofat6864 - I would still replace it
da
@danj I added some battery wake logs to the post. Do you think this narrows down the problem?
da
@jimmysofat6864 - The logs look reasonable. I'm still thinking bad battery.
da
@danj In the logs there seemed to be a lot of wake requests in the middle of the night for no reason though. If you scroll further there was a lot going on.
da
Mostra altri 4 commenti
Aggiungi la tua risposta
jimmysofat6864 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 212
