Salta al contenuto principale
Una fotocamera digitale Panasonic rilasciata nel settembre 2013. La fotocamera è dotata di zoom ottico 60x e di funzionalità per video e audio in HD.
Flash does not light up
I have a FZ72 (which is very similar to FZ70).
The flash does not work. If I open it, the camera recognises it and also preloads the flash. But if I press the button to take a photo, the picture is taken and no flash lights up.
I assume the cables could be broken, because for some time the flash only worked, if I pulled the case of it a bit backwards.
My question is, what is the tiny blue device behind the flashlight. Also there are 4 cables altogether. Which could be broken? Is it possible to fix it at all?
Immagine
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
Hi @hilfs08,
Check the capacitor and the connections to the capacitor are OK. This component provides the power for the flash to operate.
Punteggio 1
1 Commento:
Unfortunately this did not help. The cables to the flash are covered on the flash-side by rubber, so you cannot measure anything. However I tried to discharge the capacitor and it recharged after turning on, but still no flash. :/
I assume the cable is broken somewhere, but since it is tightly attached to the light itself, I would have to find a new set somewhere...
da
Aggiungi la tua risposta
Phil sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 31
Tutti i Tempi: 771
