Salta al contenuto principale
Smartphone designed by Xiaomi in the Redmi Note line.
LCD won't turned on
I just changed my LCD, at first it can turned on
But after a night the LCD is turned off, the battery is working fine, the charging light indicator is on, but the screen just can't turned on, like its not plugged in. I wonder which is the cable responsible for this cause
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Definitely try to reseat the display cable and see if there is any change. Otherwise try to see if putting the old screen back causes the picture to return, as there is the potential that you received a defective screen.
Punteggio 1
Parti e strumenti popolari
Aggiungi la tua risposta
Yasub Arkan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 91
