Can you replace the battery?
The pixel buds disconnect whenever they are removed from the case. I think the batteries are bad. Is it possible to replace the battery?
Questa è una buona domanda?
Hi,
Here’s the Ifixit Smontaggio dei Google Pixel Buds 2 guide which shows how to open the ear buds.
The guide was only to show the internal components and is not intended as a repair guide because of the damaging way in which the earbuds have to be opened.
The battery is a Varta CP1240 A3 (supplier example only) if you think that you want to try and replace them
If anyone is attempting this repair, I had good results with using a pair of pliers and gently applying enough pressure to bend the plastic slightly to crack the seal with minimal damage to anything else
I don't believe it is possible to open these earbuds without damaging the casing. Therefore, you cannot replace the battery.
Ultime 24 ore: 3
Ultimi 7 giorni: 20
Ultimi 30 giorni: 108
Tutti i Tempi: 9,662
1 Commento
I'm not seeing replacement batteries for the buds themselves, and the process looks pretty destructive. These aren't made to come apart.
da brandon k
