Salta al contenuto principale
L'Oster Expressbake CKSTBRTW20 è una macchina per il pane elettrica rilasciata nel 2009, in grado di preparare 0,9 kg di pane in meno di un'ora grazie alla funzione Expressbake.
Device has stopped mixing.
Hello! I recently picked this up at a thrift shop since I have always wanted to try one. I’ve used it 7 or 8 times and the last couple times the paddle would stop spinning to mix the ingredients. I thought it was due to gunk on the paddle or the inner container wasn’t inserted properly. This last time it mixed maybe two times and then would have an audible “click” sound instead of turning the paddle. Does anyone know how to fix the motor or attachment?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Andra Hutton could be the motor as well as the electronics. Let’s see what it looks like I suggest you start by disassembling it using something like this guide Sostituzione camera di cottura interna Oster Expressbake CKSTBRTW20
Make sure that mechanically it all looks okay. You can always post some of your devices images, with your QUESTION, while you do the work. that way we can see what you see and possibly assist you further. Let us know if you find some oddities etc. Aggiungere immagini ad una domanda
Immagine iFixit
Guida
Difficoltà:
Molto facile
2 - 5 minutes
Immagine Oster Expressbake CKSTBRTW20 Camera di cottura interna
Guida
Difficoltà:
Moderato
20 minutes
Punteggio 0
Aggiungi la tua risposta
Andra Hutton sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 14
Tutti i Tempi: 461
