Salta al contenuto principale
La prima generazione del crossover SUV di lusso Lexus RX300.
Location of brake module
My brake light aren't working. Have already replaced the pedal switch
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta più utile
Hi,
What is the model of the vehicle i.e. RX300, RX400, RX450 etc?
Did you check that the Brake fuse (aka Stop fuse) is OK?
Here’s an image taken from the 2000 RX 300 series service manual which details how to test the brake light circuit.
Immagine
(click on image to enlarge)
Hopefully this is of some help.
Punteggio 2
3 Commenti:
How do you replace the brake module on a 2002 Lexus RX 300
da
@M Haag what are you referring to as the brake module? What is wrong with yours?
da
My brake lights don’t work checked everything but module
da
@M Haag
I think that the 2002 model is the same as the 2000 model.
If so there's no "brake module" per se.
Did you test the "light failure sensor" as described in the image above?
Here are some images from the Lexus RX300 MCU15 series that shows the brake light circuit. I believe that this series covers the year range of your vehicle.
Immagine
Immagine
(click on images)
Punteggio 0
Aggiungi la tua risposta
Jackie High sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 8
Ultimi 30 giorni: 28
Tutti i Tempi: 1,115
