Salta al contenuto principale
Lanciato da Samsung a marzo 2016. Modello SM-G930.
phone won't turn on even when plugged in
awhile back the phone randomly glitched out when using it and i couldnt turn it back on, tried different button combinations and nothing worked, tried plugging it into the charger and nothing, waited a week or so to see if the battery would drain and try then but still nothing, no idea what to do now or if the phone is 100% dead, would like to atleast wipe the data off before sending it into a phone recycling place, any help here is welcomed, thanks in advanced!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi,
Do you have any testing equipment?
Multimeter and a usb amp meter would be very usefull.
If you simply want to wipe the phone before recycling it, then one thing you could do is extract the motherboard and drill a hole through it.
I hope this helps
Punteggio 1
1 Commento:
dont have a usb amp meter and think ive got a mutlimeter here somewhere
da
Aggiungi la tua risposta
Andrew Osborne sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 52
